Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
It may be bad manners to talk with your mouth full, but it isn't too
good either if you speak when your head is empty.
www.control.com/rss/
I work in a cable factory. Here we have payoffs for paying off cable for each process. Payoffs are huge structures where a drum (bobbin) is hung and rotated so that cable can be unwound for the next process.
I have observed that for certain types of cables they use "torque mode" and for certain other types of cable they use "dancer mode" for paying off. Can anybody explain what's the difference between the two modes?
They work in different ways. Torque mode is typically just a constant drag on the drum. In other words, a fixed amount of torque is used to resist the turning of the drum. If the cable were disconnected from the drum, it would tend to wind the cable back onto the drum. The problem with this setup is that the torque setting to produce a certain tension changes as the diameter of the drum changes while it it payed off.
Dancer mode uses a sensor on the cable to essentially measure cable sag. Either torque or speed of the drum is automatically adjusted to keep that same tension.
Dancer mode uses a "dancer" sheeve or set of sheeves that maintains tension on the wire with the use of an input regulated by a pot that moves when the sheeves go up and down... Torque mode usually employs the use of amperage on the capstan (or pulling) motor(s) to slow or speed up the take ups and payoffs. Are you using Fincor drives with the master control reference board?
They are different methods of cable tension control. Torque mode involves tension control by regulating payoff reel load current. Dancer mode would involve the use of a dancer roll mechanism, in which the physical position of a tensioning roller is regulated in order to control cable tension. Modern drive systems utilizing motor torque regulation typically provide better tension control than dancer systems. Maybe your newer process lines employ the torque method, and the older lines utilize dancer systems?
Related articles from Control
Engineering magazine- Siemens announces motors, drives, and motion control advances
- Wurldtech Achilles cyber security testing
- OMAC guidelines ease design, programming, integration
- Webcast to examine best practices for adopting Microsoft Windows Vista
- Vision sensor inspects for defects at any part position, rotation
- Smart vision sensor features simple setup, high-speed inspection
- Cameras with DSP coprocessors offer multiple options
- GHS has EAL6+ operating system security certification; launches Integrity Global Security
Subject to its Terms of Use.
