member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
If I traveled to the end of the rainbow
As Dame Fortune did intend,
Murphy would be there to tell me
The pot's at the other end.
-- Bert Whitney
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
Communications master - slave
Communications systems and equipment. topic
Posted by Anonymous on 30 October, 2007 - 11:08 pm
I am developing an application for Wago I/O system with Modbus devices. I am using Wago (750-841) ethernet controller. The Wago PLC must work as a master to the slave devices, which are connected to the Wago I/O Modbus through RS485 serial interface module 750-653/003-000.
I have tried to use the library "Modb_l05.lib" (http://www.wago.com/wagoweb/documentation/app_note/libraries/Modb_l05 .lib , http://www.wago.com/wagoweb/documentation/app_note/libdoku/ml01101e.pdf) to send and receive data, but I didn't get any data back. I am not interested to write anything to the slaves. I only want to receive data from them. My slave device is a digital multimeter (Lovato). Here is the program in CoDeSys with the parameters I am using:
PROGRAM DataExchange
VAR
Master: MODBUSMASTER_RTU;
SlaveAddress:BYTE;
FunctionCode:BYTE;
St artAddress:WORD;
NumberOfPoints:WORD;
start: BOOL:=TRUE;
state: INT;
send:typRing_buffer;
rec: typRing_buffer;
slavedata:ARRAY[0..100] OF BYTE;
i: INT;
END_VAR
SlaveAddress:=1;
FunctionCode:=16#4;
S tartAddress:=1;
NumberOfPoints:=2;
start:=TRUE;
Master(Sl aveAddress:=SlaveAddress ,
FunctionCode:=FunctionCode ,
StartAddress:=StartAddress ,
NumberOfPoints:= NumberOfPoints,
bCOM_PORT:=2 ,
cbCOM_BAUDRATE:=1920,
cpCOM_PARITY:=0 ,
csCOM_STOPBITS:=1 ,
cbsCOM_BYTESIZE:=8 ,
cfCOM_FLOW_CONTROL:=4,
TimeOut:=t#100ms ,
StartFunction:=start ,
ReceiveBuffer:=rec ,
SendData:=send);
Is there something mising? Must I use some other libraries? Is there a ready application in CoDeSys, which configures the PLC as a master for the communication with the slave devices through RS485 serial interface module 750-653/003-000?
I hope for some replies and solutions.
Thanks!
Internet Explorer 6.0 Fix
Advertisement
