Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Worst Vegetable of the Year:
The brussels sprout. This is also the worst vegetable of next
year.
-- Steve Rubenstein
year.
-- Steve Rubenstein
www.control.com/rss/
ISO control system for servos/analog sensors/analog outputs and communicationsHello,
I'm currently a Sr at Drexel University and working on my Sr Design project. My portion has to do with automation, and I am searching for a controller that will allow for servo control, analog inputs (reed switches/potentiometers) and analog and digital outputs, as well as some sort of communications channel, IE RS232, WIFI, or any other sort of system that can be made to function remotely. I've used IFI's controller in the past but have had problems with the unit overheating. I started looking into Lynxmotion's products and was interested in maybe National Instruments products but am open to any solution that many of you have used in the past. Please let me know what you have used before and possibly what known issues there are.
Mike
mgp27 @ drexel. edu
Mike
mgp27 @ drexel. edu
Look at new digital Elmo servo amp (http://www.elmomc.com) - I hope you'll find what you need.
Mike,
You might also check out Opto22.com
They have a modular PLC system that uses ethernet.
The programming language is flowchart, the software is free, and you get good assistance if you call them. They will even recommend a compeditor if they think it's a better fit.
Good luck with your project
Roy
Roy
Thanks guys,
I've decided upon the NI Compact RIO setup. My only problem is I have no experience in Labview so there is a huge learning curve for this. But as we had already had the hardware and software in the lab, it appeared to be the best option for now. Hopefully I will be saying the same thing in June when I have to present a completed project.
-Mike
-Mike
Related articles from Control
Engineering magazine- Wonderware focuses on front-line innovation
- Wonderware announces new system integrator certification
- Mobility dominates WonderWorld partner and technology expo
- CAD / project management integration supports distributed engineering
- OPC Foundation to release analyzer devices integration draft specification
- Wonderware applauds users of winning applications
- Embedded automation: Compact computer supports multiple operating systems
- Display panel has built in functions, diagnostics
- Pepperl+Fuchs acquires Christensen Display Products
- Hot news in temperature: Industrial thermostat, infrared linescanner
Subject to its Terms of Use.
