member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
You buttered your bread, now lie in it.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
GPRS for two way SCADA applications
Communications systems and equipment. topic
Posted by Alfred Manohar on 5 November, 2007 - 4:12 pm
GPRS usage for two way SCADA communications applications - slave to master is understandable in a way that the slave with GPRS connectivity (and a dynamic IP address of course!) will log on to a static server's IP address (that of the master with a static IP address provided by the Internet Service Provider) and pushes the data to the master. However, the master to slave (RTU) communication is not possible without a static IP address within the slave. This is being achieved through SMS (control signal command) from master to slave on its MIN (Mobile Identification Number).
I would like to understand how this is done, and if there is a possibility of Master/Slave communication without the SMS route and without a static IP address at the slave.
Thanks in advance.
Posted by CH on 11 December, 2008 - 9:29 am
<I would like to understand how this is done, and if there is a possibility of Master/Slave communication without the SMS route and without a static IP address at the slave.>
That is a very good question. I also would like to know the answer to that.
The only way I see this happening is if the device with a dynamic IP address (slave in your example) has the ability to associate with some DDNS (Dynamic DNS) service. Then the master would use the hostname of the slave as apposed to the IP address. Providing the master supports using hostnames, of course.
Posted by Rod N on 5 January, 2009 - 10:41 pm
Go to controltoolbox.com and read NetPro-ModServ developer's manual. The remote does not need to have static IP address while the communication is two-way. In a nut-shell, the commands are polled by the remote with a proper timeout to avoid loading the channel.
Rod
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Control Engineering magazine subscription
Advertisement
