I have a problem with my multiport board.
My multiport board is an MOXA C104H PCI board installed in a PC with QNX with RealFlex.
In setting up telemetry PCU screen of flexview saw that the minimum speed is 1200 baud.
The problem with the MOXA board installed on realflex server with QNX, the hi-performance mode of MOXA board multiplies the output speed 8 times.
Can I delete or cancel the hi-performance mode of MOXA board?
We want to work to 4800 baud then 4800/8 = 600 baud. We need to set the rate at 600 baud in the telemetry setup. I saw a telemetry configuration file. Can I modify this file to be able to work at 600 baud? For example the line 1200/1200 change it 600/600?
Greetings, and thank you for your time.
