Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Power corrupts. Absolute power is kind of neat"
-- John Lehman, Secretary of the Navy 1981-1987
www.control.com/rss/
I need to find out the number of instructions executed by my processor per sec.
I wrote a code with 10 simple instructions in a loop. Now I want to sent an interrupt to this program after 1 sec. so that I can count the number of instruction executed per second. How can I set my RTI to 1 sec. and how can I interrupt my program?
I would suggest turning the problem around the other way. Run a set number of loops, and time how long it takes to execute it. Then you just need a
precision timing function. Run the loop with various numbers of iterations so you can extrapolate the timing overhead (assuming this is a linear function).
For timing, the POSIX C documentation states:
NAME
gettimeofday - get the date and time
SYNOPSIS
[XSI] [Option Start] #include <sys/time.h>
int gettimeofday(struct timeval *restrict tp, void *restrict tzp); [Option End]
DESCRIPTION
The gettimeofday() function shall obtain the current time, expressed as seconds and microseconds since the Epoch, and store it in the timeval structure pointed to by tp. The resolution of the system clock is unspecified.
If tzp is not a null pointer, the behavior is unspecified.
RETURN VALUE
The gettimeofday() function shall return 0 and no value shall be reserved to indicate an error.
ERRORS
No errors are defined.
NAME
SYNOPSIS
DESCRIPTION
RETURN VALUE
ERRORS
Related articles from Control
Engineering magazine- Rockwell Automation releases VantagePoint for plant data visualization
- Industrial Ethernet advantages using Profinet protocol
- Tips for sustainability in manufacturing
- Deadline extended: Nominate award winning products now for upcoming competition
- Video listen in: Making Coriolis two-wire demands small sacrifices
- Innovative manufacturing companies have a profit advantage over low-price firms
- Fieldbus Foundation Seminar: Chicago
- Radios for long-distance use in industrial mesh network
- Fast HMI application development software
- HMIs: Rugged, instrument-grade-glass on projected capacitive touchscreens
Subject to its Terms of Use.
