Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Real Users hate Real Programmers.
www.control.com/rss/
My company owns some asphaltic plants. One of them is equipped with WEG's Soft-Starters and Frequency Inverters. They are connected by MODBUS/RTU.
I want to interface that network with our AB SLC 500 5/03.
My question is:
Is there any way to do that? Which products or devices should I need?
Thanks a lot.
My question is:
Thanks a lot.
Alejandro:
Try Prosoft.
You can find what you need at
http://www.prosoft-technology.com/content/view/full/5757.
Regards and good luck !
Pablo
Try Prosoft.
Pablo
Alejandro,
You can have a Prosoft 3150 MCM module installed in the SLC rack. It is a programmable commonly used for A-B PLCs to interface with Modbus devices.
Alejandro,
Check out the "Prosoft" module, these slot into AB racks and have AB approval.
I just used one and it seems to have lots of features including a sample program to get you started. The one I have has 2 ports that can be RS-232, 422 or 485 Master or Slave.
Roy
Roy
Prosoft is an Allen Bradley 'partner', specializing in communications modules.
http://prosoft-technology.com/
Naviogate from their home web page navigation bar on the left to
products > for Rockwell Automation > platform > SLC > scroll down to either
Modbus RTU/ASCII Master/Slave Communication Module MVI46-MCM, or
Modbus TCP/IP Client/Server Communication Module MVI46-MNET
David
David
It seems you are right!
This product is what I need. I'll get in touch with ProSoft.
Thanks a lot.
Thanks a lot.
The most common and straightforward way to interface A-B controllers and Modbus network devices is chassis-mounted modules from Prosoft.
You want the MVI46-MCM module for Modbus RTU over serial links.
You could use our Omnii-Comm product for this application. It is very easy to use and requires no PLC programming. Please have a look at these two links, one for a slot-mounted unit
http://www.miille.com/166-20X.pdf and another for a stand alone, DIN rail mounted converter
http://www.miille.com/din266-p00.pdf.
Either will solve your problem.
If you have further questions, please contact us at sales@miille.com
Thanks.
Jerry Miille
Thanks.
Jerry Miille
Related articles from Control
Engineering magazine- Industrial Ethernet advantages using Profinet protocol
- Fieldbus Foundation Seminar: Chicago
- Radios for long-distance use in industrial mesh network
- Embedded: Precise Time Protocol enables new-generation Ethernet mobile networks
- Optimize field wiring with decentralized IP 67 fieldbus system
- Pack Expo: SERCOS real-time communications for packaging
- Modbus RTU master, distributed I/O in compact package: microNCS
- Cordsets meet Fieldbus Foundation H1 Type A cable requirements
Subject to its Terms of Use.
