member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Everybody wants to go to heaven, but nobody wants to die.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
Hydraulic valves
Engineering and workplace issues. topic
Posted by instruguy on 17 November, 2007 - 1:51 am
Can anybody please guide me, what are selection criteria for hydraulic valves over pneumatic valves? In which situation they are preferred? Is there any international standard for selection of hydraulic valves?
Thanks in advance.
Posted by Roy on 17 November, 2007 - 10:06 pm
Hi instruguy,
In 40 years I have rarely seen hydraulic actuators used unless it's a water control valve using the line pressure as the driving force(check out Singer or Clayton).
Hydraulics requires a source of HP fluid e.g. motorized gear pump, oil tank filters etc. wheras in most cases air pressure is available.
The systems I have seen have been dedicated to a single specialized valve or packaged system operating at very high line pressure where the force required would call for a huge pneumatic actuator.
Don't forget electric actuators, some of the newer ones incorporating stepper motor drives are very good but again usually only where air is not available. Electric damper actuators are very common.
In my oppinion.
Start with air (unless you are dealing with large water valves, in which case water powered), Electric if no air, Hydraulic only in special cases.
I am not aware of a standard.
Hope this helps
Roy
Posted by instruguy on 21 November, 2007 - 3:51 pm
Hi Roy
Thanks a lot.
Posted by turbino on 11 December, 2007 - 1:48 am
Hi Roy,
Are you familiar with water-powered hydraulic valves used in old water pumping stations to automatically open/close the pump check valve at a certain pressure setting? If you do, can you share with me its piping schematic diagram and how it works? Also, I would like to know which valves need to opened/closed to open/close in the piping circuit to test/exercise the check valve. I know there is a dump valve on it which can be opened to close the check valve in the event of emergency. Thanks in advance.
Internet Explorer 6.0 Fix
Advertisement
