Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Fuch's Warning:
If you actually look like your passport photo, you aren't well
enough to travel.
enough to travel.
www.control.com/rss/
I want to use one windows HMI PC with Wonderware on Modicon 434 CPU. the CPU is used in redundant configuration. how can i connect it to CPU so that HMI is alive after CPU switching?
From my experience, no special configuration needed to connect wonderware to Modicon Quantum 434 CPU in redundant configuration, but you have to use Modbus ethernet or modbus plus for communication protocol between wonderware I/O server and CPU 434.
Once you assign TCP/IP address (for quantum ethernet module) or modbus plus address (for and modbus plus port at 434 CPU) for primary CPU, one level higher node address will be assigned to standby CPU. The two address will switched automatically between primary and stanby CPU in case of switchover
So, wonderware I/O server only need to access primary CPU address and no need to know stanby CPU address or when switchover will be happen
Your question is a little vague. Are we talking true 'HOTSTANDBY'? What s/w?
What coms are you using MB+, Modbus Modbus TCP/IP?
Where is the coms connected on the quantum, add-on module in rack, or directly from CPU?
Related articles from Control
Engineering magazine- Rockwell Automation releases VantagePoint for plant data visualization
- Tips for sustainability in manufacturing
- Deadline extended: Nominate award winning products now for upcoming competition
- Video listen in: Making Coriolis two-wire demands small sacrifices
- Fast HMI application development software
- HMIs: Rugged, instrument-grade-glass on projected capacitive touchscreens
- Third-party remote I/O available for ControlLogix, CompactLogix
- Control system and instrumentation design software
Subject to its Terms of Use.
