member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
What sin has not been committed in the name of efficiency?
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
Compressor Pressure Discharge intermittent fluctuations
Applications topic
Posted by B.E on 23 November, 2007 - 11:22 am
On the <I> Mark V Speedtronic, we received the following intermittent Diagnostic alarm:
Droop Description
0282 IOMA CPD input hardware problem
Also we notice that, the Compressor Discharge Pressure (CPD) indication on <I> is fluctuating intermittently.
For the moment, the machine is still running and on the <I> we locked this alarm.
Can any one suggest, what is the reason for this alarm?
Posted by CSA on 28 November, 2007 - 12:05 am
From a very old <Q> Diagnostic Alarm "Help" file:
0282 ;IOMA CPD INPUT HARDWARE PROBLEM
CAUSE The CPD input does not pass internal diagnostic checks.
EFFECT Bad I/O data, particularly for the CPD input.
ACTION Try replacing the DCC/SDCC card.
Is the panel a SIMPLEX or a TMR panel? Which processor is this Diagnostic Alarm being generated for?
It's either an intermittent transmitter or transmitter wiring (easier to check/resolve and should be done *before* replacing the DCC/SDCC card) or it could be a cable problem (follow the signal using the Signal Flow Diagrams in Appendix D of the Mark V Application Manual, GEH-6195), it could be a card connector problem (corrosion, as has been reported several times on control.com).
Posted by B.E on 30 November, 2007 - 12:12 am
Thanks for your reply,
The panel is TMR. The diagnostic alarm is being generated intermittently for all processors R, S & T but, not at the same time, sometimes on R only, sometimes on S only and sometimes on T only.
Now, the machine is running, we will wait until the next Shut-Down to check the wirings, the transmitter and maybe to replace the card.
Posted by CSA on 1 December, 2007 - 10:48 am
Look at the Mark V Application Manual, GEH-6195, Appendix D, the page "<Q> Core - Compressor Discharge Pressure Inputs on TBQB" for details on the CPD input(s). A TMR Mark V requires three CPD inputs, and some turbines only have one, so the TBQB can be configured to "fan" one input to all three control processors. NOTE: If this is done, and the CPD transducer is a 4-20mA transducer, only *one* dropping resistor must be IN.
If the alarm is happening on all three processors, it's likely something that is common to all three processors--like a single transducer, or an intermittent connection in the circuit of a single transducer, or the TBQB card.
Or, corrosion on the cable connectors of the cables between the TBQB and the TCQCs, or the TCQCs to the DCCs/SDCCs.
Advertisement
