Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Moon, n.:
1. A celestial object whose phase is very important to
hackers. See PHASE OF THE MOON. 2. Dave Moon (MOON@MC).
www.control.com/rss/
I have a siemens OP27 and a siemens PG the latest
PG M.
This PG has a 25db COM port and the OP has a 15db communication port.
Can someone give me the pinouts for this cable , i searched internet for days , but it seems that a 15db port is not common?
Thanks a lot..
PG M.
Thanks a lot..
The port IF2 on OP27 has pinout:
2 TTY RxD-
6 TTY TxD+
7 TTY TxD-
9 TTY RxD+
The port on the PG has pinout:
9 TTY RxD+
10 TTY RxD-
18 TTY TxD+
21 TTY Txd-
Alternatively you can use the MPI port of your PG and OP27 to communicate.
Bryce
2 TTY RxD-
6 TTY TxD+
7 TTY TxD-
9 TTY RxD+
9 TTY RxD+
10 TTY RxD-
18 TTY TxD+
21 TTY Txd-
Bryce
Hello;
The PG has 2 com ports, a 9-pin for RS-232 and a 25-pin for TTY communications. On the OP27, one 15-pin connector (IF2) can be used for RS-232; we have used a standard 15-pin to 9-pin converter with a null-modem cable in older projects.
Another 15-pin connector (IF1A) can be used for TTY connections, mostly with a S5 PLC; if you need to use TTY with the PG, cable 6ES5 734-1BD20 will work (it has 25-pin and 15 pin connectors, with a current loop circuit built-in).
Hope this helps,
Daniel Chartier
Hope this helps,
Daniel Chartier
Related articles from Control
Engineering magazine- Industrial Ethernet advantages using Profinet protocol
- Fieldbus Foundation Seminar: Chicago
- Radios for long-distance use in industrial mesh network
- Embedded: Precise Time Protocol enables new-generation Ethernet mobile networks
- Optimize field wiring with decentralized IP 67 fieldbus system
- Pack Expo: SERCOS real-time communications for packaging
- Modbus RTU master, distributed I/O in compact package: microNCS
- Cordsets meet Fieldbus Foundation H1 Type A cable requirements
Subject to its Terms of Use.
