- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
I plan to use an Industrial PC and .NET. But I haven't got much experience in PIDs!!
I appreciate any guidance from people exposed to greenhouse control, and PC coding for PIDs!
PID control from a PC isn't really as much about the "code for the PID math" as it is about the interfacing hardware. Writing code to do the math for a PID algorithm "demonstrator" is pretty trivial (search Google), but if you really need to control heater fans and dampers from a PC you've got to interface with the real world hardware, which isn't necessarily so trivial. Especially if your background is .NET software and not industrial hardware.
Forget about the PID functions until you can accurately read the sensor for your measured variable, i.e. temperature, moisture, conductivity or humidity for a greenhouse most likely, and until you can adequately command the position of your end effector for the manipulated variable, most probably a valve position or pump motor speed. Without the measuring and manipulating parts your project is merely a show and tell exercise. Once you can accurately read the measured variable and control the manipulated variable, then worry about the control algorithm.
Michael
Michael Batchelor
www.IndustrialInformatics.com
- HMI/SCADA: Microsoft Fluent technology helps enhance Proficy iFIX 5.0
- HMIs: NASCAR pit crews, Vista users get Simatic options
- HMI: Monitors, graphic panel improve images, offer ruggedness
- Software: Improve chemical processes, predictive modeling, viscosity simulation
- Listen in exclusive: Wonderware Innovation Partners to create vertical software faster
- Listen in exclusives: Wonderware launches innovator program; Kepware helps Wonderware
- Speedier production management application development
- OPC server software enables multi-vendor substation automation
- Downtime avoidance: Proactive support services seek to eliminate diagnostic delays
