- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
-- Voltaire
www.control.com/rss
I am able to boot up the program in a DOS window operating under Windows XP. However, I'm unable to print out the logic. Ideally, I would like to convert the logic printout to a PDF file.
Can someone help?
depstein @ mayfran. com
Do you have the UPF.exe at the Modsoft directory? That small program should help you to setup printer. The only restriction can be the following: you can select between ports LPT1, LPT2,..., com1, com2... There is no UPS port.
I use Win2000 and HPdeskjet690 Printing is OK.
The another solution is to "print" to the Modsoft.out text file and then copy to the Word...
Good luck.
Your .out file should be in your modsoft rooth folder (usually c:\modsoft) and is openable with any text editor. Not very good graphical look, but hope this help...
- Temperature, relative humidity sensors pair with wireless network
- Intrinsically safe accelerometer expands line of hazardous area sensors
- Power: Digital converter growth; fuses, harvesting, supplies, transformers, UPS
- Terminal blocks: 125 A, 1,000 V, 15 mm pitch; 100 kA short circuit current rating
- Enclose, protect: 2 plastic enclosures; device measures heat, airflow
- Control Engineering System Integrators Hall of Fame
- Listen in: Companies continue DCS investments
- New podcast: Planning your DCS migration
- Control platforms: An industry standard perseveres, in many forms
- IMTS: Robots will fight at the manufacturing technology show
