Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Jacquin's Postulate on Democratic Government:
No man's life, liberty, or property are safe while the
legislature is in session.
www.control.com/rss/
Hello everyone,
I have just bought a house in Fort McMurray Alberta (gasp) that depends on water delivery/storage and have already found out first hand the joy of running out... not fun. I have since learnt a little bit about the system but I think it could be improved and I would like your help. Currently the pump is only on a breaker, there is no float switch for it and nor is there one for when the driver fills up the tank (he waits for the gyser then shuts down).
How hard is it to put in a switch for the pump after the fact and what is the best way to nodify the driver that the tank is full? (I did read the bouy and stick method.)
Thank you,
Trevor
Thank you,
Trevor
Assuming that you won't easily be able to install a level switch in the bottom of the tank, you could look at using ultrasonic sensors for empty & full levels.
http://en.wikipedia.org/wiki/Ultrasonic_sensors
Tom,
An ultrasonic would be ideal but this tank is probably buried 1 to 2 meters below the surface and hard to get at.
Trevor,
You could place a level switch assembly or transmitter on the suction piping of the pump. This would allow you to select the full level (put a light near the fill station to indicate to the delivery person the tank is full) -- say 90% (I used to live in Grande Prairie and our temperature values were equivalent -- the exhaust thru a geyser is hazardous since the build up of ice in the vent tube will cause problems with low suction pressures or implosion).
Put another alarm at the refill spot (this depends on how long it takes to get a refill to the tank and your usage rate) so you can order a new water load.
For help with equipment contact Muis controls Edmonton (Bill Muis is the owner -- I worked with him in the late 70's--)
Have fun
Dennis
Trevor,
Have fun
Dennis
Related articles from Control
Engineering magazine- Wonderware focuses on front-line innovation
- Wonderware announces new system integrator certification
- Mobility dominates WonderWorld partner and technology expo
- CAD / project management integration supports distributed engineering
- OPC Foundation to release analyzer devices integration draft specification
- Wonderware applauds users of winning applications
- Embedded automation: Compact computer supports multiple operating systems
- Display panel has built in functions, diagnostics
- Pepperl+Fuchs acquires Christensen Display Products
- Hot news in temperature: Industrial thermostat, infrared linescanner
Subject to its Terms of Use.
