Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Jone's Law:
The man who smiles when things go wrong has thought of someone
to blame it on.
to blame it on.
www.control.com/rss/
I am programming ControlLogix Ladder Diagrams using RSlogix 5000. I bought a chassis with a Processor only. There are no I/O modules. The processor can talk with my Laptop using serial communication port.
When I go online with ControlLogix processor, I found an interesting issue: I cannot TOGGLE every XIC and OTE. I also cannot FORCE ON every input and output address (both DI and AI). Could any expert tell me what is going on?
I don't know about the forcing, but if there is code in the processor, it is entirely possible that the code is resetting the toggled bit. Using the programming software to trun the bit on or off, does not prevent the plc code from affecting its state.
Billy, Using TOGGLE does not force or override a bit/bool that is already being set or reset, all it does is toggle the stat of that bit. If you have an OTE and tried to toggle it then quite likely the logic to the OTE is setting/resetting the bit and your TOGGLE does nothing or may change the state for one scan.
FORCES only work on digital IO and not on internal bits, the same as it does for SLC and PLC5's.
And FORCES do not work on Integers/Reals at all, meaning that they will not FORCE Analogue IO. You can do a similar thing with a Integer or Real tag by typing in a relevant value in as the data, but if something else is 'writing' data there then it will be over-written, for example an Analogue input module.
Trevor.
Trevor.
Thanks you so much Trevor. You helped me a lot.
Related articles from Control
Engineering magazine- Rockwell Automation releases VantagePoint for plant data visualization
- Tips for sustainability in manufacturing
- Deadline extended: Nominate award winning products now for upcoming competition
- Video listen in: Making Coriolis two-wire demands small sacrifices
- Fast HMI application development software
- HMIs: Rugged, instrument-grade-glass on projected capacitive touchscreens
- Third-party remote I/O available for ControlLogix, CompactLogix
- Control system and instrumentation design software
Subject to its Terms of Use.
