member
passwd
remember me on
this computer.
- join now -
Select a topic of interest:
...and press:
Control.com Stuff
Remember, drive defensively! And of course, the best defense is a good
offense!
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the candi department...
SA85
Posted by senya on 13 December, 2007 - 12:03 am
We have been using SA85 in Windows 98 and now we have switched over to Windows XP and found it is not sensing the hardware. The software MBX driver suite has been loaded... but the hardware could not be installed.
Posted by Fred Loveless on 14 December, 2007 - 12:41 am
Are you trying to use the MBPLUS.VXD driver that you used on the 98 box, or have you installed the MBPLUS.SYS driver for the NT and higher OSes? My fist suggestion would be to check with Modicon or CyberLogix to get the most recent driver set.
Fred Loveless
Support Manager
Kepware Technologies
Posted by Chris on 14 December, 2007 - 1:11 am
Try setting the Virtual MBX Driver to support 16 bit windows applications.
This will be located in Program Files||WinConX||Virtual MBX Driver||Virtual MBX Driver Configuration (if you have installed the drivers from the disk that comes with the SA85 card).
Posted by William Hinton on 14 December, 2007 - 1:15 am
We had the same issues and we found that we had 2 options:
1) Change back to Win98/ME
2) Replace the SA85 cards to the newer Windows 2000/XP hardware versions. Caution, when buying the new version as some of the older ISA versions will still not work and you may not have a PCI adaptor slot in your motherboard.
I hope this helps,
William Hinton
Posted by Benoit on 15 December, 2007 - 2:30 pm
An other option you have is use a PC with an ISA slot and a network card, install Windows NT and then install your SA85 using MBX Driver and installing all options. You can now configure your NT Worksation as a remote MB+ server, available for any computer on your TCPIP network on wich you install and configure MBX Remote client option. As i know, Windows NT is the only OS that will support both SA85 & Remote MBX Server mode.
Internet Explorer 6.0 Fix
Advertisement
