Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Virtual" means never knowing where your next byte is coming from.
www.control.com/rss/
I am simulating the behaviour of a power plant. I have modelled a rectifier to convert AC to DC. I am not supporting battery. I have supported some keywords which will give alarm when battery is discharged. I am confused in the functionality at some instances. Suppose I have a circuit like:
generator-circuit breaker1(cb1)-AC bus-cb2-rectifier-cb3-DC bus-cb4-DC motor, and AC bus is at 345 V and I am displaying electrical quantities at inlet and outlet of each equipment.
1. If cb1, cb2 are close and other cbs are open, then should there be DC voltage as output of rectifier, i.e. around 219V or AC voltage, i.e. 345?
2. When all cbs are close and let's say DC motor is drawing 20 A of current (which will of course be calculated taking DC voltage as inlet), then what should be the current through rectifier? As of course they are in series, so it should be 20 A only right? Considering this to be correct, so
AC bus voltage is 345 v and 20 A current, pf let's say 0.98 lagging and rectifier output voltage as 219 and 20 A and pf=1. So there will be huge difference in power?? So is it correct??
Waiting for the reply...
Related articles from Control
Engineering magazine- Wonderware focuses on front-line innovation
- Wonderware announces new system integrator certification
- Mobility dominates WonderWorld partner and technology expo
- CAD / project management integration supports distributed engineering
- OPC Foundation to release analyzer devices integration draft specification
- Wonderware applauds users of winning applications
- Embedded automation: Compact computer supports multiple operating systems
- Display panel has built in functions, diagnostics
- Pepperl+Fuchs acquires Christensen Display Products
- Hot news in temperature: Industrial thermostat, infrared linescanner
Subject to its Terms of Use.
