member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
Think of your family tonight. Try to crawl home after the computer crashes.
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
PLC values sending to a PC
PLCs topic
Posted by khkertje on 19 December, 2007 - 1:53 am
I have to make a program in VB 2005 that reads short values that I send from a PLC with Modbus TCP/IP.
The PLC has an IP address and also a port number.
Does somebody have a code so I can read the values in VB 2005 so I can show that on a screen and save those values?
Thanx.
Posted by Sanjay Sheth on 21 December, 2007 - 1:01 am
Take a look at the free nModbus .NET library ( http://nmodbus.com/ ). I've used it in the past with VB 2005 to do just what you are asking.
Sanjay Sheth
http://rssgrinders.com/
Posted by Anonymoes on 4 January, 2008 - 11:40 pm
I think I need to use this code from that side:
using (TcpClient client = new TcpClient("127.0.0.1", 502))
ModbusIpMaster master = ModbusIpMaster.CreateTcp(client);
// read five input values
ushort startAddress = 100;
ushort numInputs = 5;
bool[] inputs = master.ReadInputs(startAddress, numInputs);
for (int i = 0; i < numInputs; i++)
Console.WriteLine("Input {0}={1}", startAddress + i, inputs[i] ? 1 : 0);
// output:
// Input 100=0
// Input 101=0
// Input 102=0
// Input 103=0
// Input 104=0
And I made this:
orts System.Net
Imports System.Net.Sockets
Imports System.Text
Imports System.IO
Module Module1
Sub Main()
Dim client As TcpClient = New TcpClient("192.168.131.44", 502)
'code for modbus
Dim startAddress As Short = 3000
Dim numInputs As Short = 100
Dim i As Integer = 0
'code for read inputs
If i < numInputs Then
Console.WriteLine("Input {0}= {1}")
'the rest of the code to write the values
Return
End If
End Sub
End Module
As you see there are a few things I can't find.
Can someone help me with the missing code?
Advertisement
