Flow divider Speed in Mark-V
If you're looking for a software signal name for flow divider speed, none exists.
You can use a frequency meter to measure the signal at the input terminal board.
Or, you can look at the scaling in the I/O Configurator, which will tell you how many Hertz equals 100%, and then look at the feedback signal (usually FQL or FQL1) which is scaled in percent, and convert to frequency.
I believe the originator asked for speed measurement; FQL1 is usually expressed in percent.
If you want to tell someone how to measure speed in terms of percent, you also need to tell them how to convert from percent to speed (frequency).
