- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
on.
www.control.com/rss/
I would also add that if you are experiencing other Diag. Alarms, especially Contact Input Failures, along with battery ground alarms, that this would also be a good time to investigate and resolve any grounds (remember, if grounds have existed for a long time, it's a safe bet there is more than one!) and check for any induced AC voltages on the contact input wiring or ripple from the battery charger output. (This would need to be done with power on the panel.) Too many Contact Input Failure, and on TMR panels intermittent Voting Mismatch Diag. Alarms, can cause communication "interruptions."
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Digital manufacturing: Autodesk Inventor shows component interactions
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
