Hi everybody
It's my first time to use Factorylink 7.5. I surched a lot to find a learning video, but without luck. Do you know a site, a book, anything that can help me as a beginner?
I will appreciate your help
Najib Lugar
Najib Lugar
Hi Najib,
You could begin reading this post: http://www.control.com/thread/1026213832#1026213873
If you web/video camera has its own ActiveX control to be inserted in any ActiveX container (only in Windows), you must install it on the same PC where FactoryLink will run and insert/configure it in your FL's mimics.
FL's Client Builder supports Java Bean Components as well if you want to use this technology to see video.
The Client Builder Help can tell you a little more about ActiveX controls.
I hope it helps.
Regards.
Saludos.
Gustavo A. Valero P.
BIConsulting C.A.
Valencia - Venezuela
gustavo.valero @ biconsulting. com
I hope it helps.
Regards.
Saludos.
BIConsulting C.A.
Hi
i am using factory link 7.5. in that for report generation, a variable specifier is required to append all the datas. it should be used in the file directory path. like this it is given in the manual. can i know how to use that and what variable specifier should be used for appending new datas in reports.
regards,
Vinoth.M
regards,
Vinoth.M
Hi John
In the nearest time will be accessible on a site
https://sites.google.com/site/aiutomation/
if it is actual for You please send me email automation.info [at] inbox.lv
Ruslan
Ruslan
"I'd love to go out with you, but I'm staying home to work on my
cottage cheese sculpture."
on 17 November, 2010 - 4:48 pm
