- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
o The three phase voltages form an equilateral triangle. Electrically, the system neutral is coincident with the centroid of that triangle. Typically, it is connected to an earth-plane at the source of supply. That is, there is equipotential between each phase and the neutral path from the generator to the load!
o If the phase-to-neutral loads are balanced when the path is interrupted, the voltage triangle remains intact, and there is no displacement of the centroid! This can be confirmed if none of the phase-to-phase loads were “damaged!”
o If the phase-to-neutral loads are unbalanced (normal expectation) when the neutral path is interrupted, the voltage triangle remains intact. Again, phase-to-phase loads are left undamaged. But, the centroid will be displaced, altering the voltage appearing across phase-to-neutral loads!
o In severe cases displacement can put the centroid outside of the voltage triangle exposing phase-to-neutral loads to extreme overvoltage!
o The degree of displacement is influenced by the degree of unbalance in the phase-to-neutral loads!
o Alternatively, if the phase-to-earth capacitance (always present) is unbalanced, then, it too will result in the centroid being displaced. However, in this case the phase-to-earth voltages also exhibit different phase-to-earth voltages!
o It would be very helpful if you could provide more forensic detail than just the word "damage!"
If you need additional infotmation, please contact me!
Regards, Phil Corso (cepsicon@aol.com)
Even with proper earthing the damage would still have occured.
- Temperature, relative humidity sensors pair with wireless network
- Intrinsically safe accelerometer expands line of hazardous area sensors
- Power: Digital converter growth; fuses, harvesting, supplies, transformers, UPS
- Terminal blocks: 125 A, 1,000 V, 15 mm pitch; 100 kA short circuit current rating
- Industrial Ethernet: High density I/O, no-tool RJ45 Ethernet connector, extenders
- RFID: Tag for boxes or polymeric containers, future trends, training
- Enclose, protect: 2 plastic enclosures; device measures heat, airflow
- Control Engineering System Integrators Hall of Fame
- User group meetings: Trade show, conference, motivational seminar, and party, all in one
- Process safety system: Flexible platform designed to increase plant profitability
