- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
-- Dr. Joy
www.control.com/rss
Which standard IEEE/IEC says that the generator capabilty has to be higher than that of a Gas Turbine and by what percentage?
Any help will be highly appreciated!
abhayambuj @ hotmail. com
If the turbine will be located at a latitude when inlet temps are generally low, a larger generator output capacity would be needed.
On the other hand; If the turbine is located at a latitude where inlet temps are generally high, it is not economical to purchase a generator where the higher turbine outputs will never be reached.
For instance, A GE Frame 7EA located at a latitude of 39 degrees would need a generator capable of 96MW with average summer output of 70MW and winter output of 93MW.
The same turbine located at a latitude of 65 degrees would need a generator capable of 120MW because it could have sustained operation at over 100MW output.
Steam turbines/generators are sized by the capacity of their steam generators.
Hope this helps.
If this is the case, the customer/consultants ask for generator reactive capability to be drawn corresponding to generator elevated output. Is this the correct practice? When Gas turbine is delivering a output of 70MW How can my reactive capability curve show 96MW output (max output at least ambient)?
- PTO reports high growth, cross-industry collaboration
- New, efficient industrial gas turbines coming
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- What process control applications are OK for wireless?
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- Affiliate integration: Advanced Automation, IAEF and EIAL become Avanceon
- Product experience: Who leads in 2008 with automation system integrators?
- Controller platform: Small-scale system bridges device gap
