member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
Don't take life seriously, you'll never get out alive.
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
from the wireless network department...
Micrologix 1100 wireless network
Networking topic
Posted by apis on 17 January, 2008 - 1:00 am
Hi, alls.
I want to develop a wireless network between Micrologix 1100. Now I communicate with 2 Micrologix 1100s using a crossover cable (ethernet port).
I try to make the connection via wireless using wifi equipment from some supliers (Belkin, Dlink), but I can not.
Could someone give some guidelines for this development?
Posted by CH on 18 January, 2008 - 1:48 am
ProSoft Technology has a wide range of wireless products. Depending on your requirements (speed, range, FH, DSSS, etc.) you can select from several different types of wireless products.
Their address is http://www.psft.com
CH
Posted by Ian Poulett on 18 January, 2008 - 11:43 pm
We can offer such equipment to do this plus we are a Rockwell Automation Encompass Partner!
Please follow the link for additional information:
http://www.westermo.com/Resource.phx/content/uk/products/elpro-rad io/wirelessethernet.htx
Best Regards,
Ian
Posted by pmas on 19 January, 2008 - 12:46 am
PMAS provides the wireless solution using GPRS for all the industrial protocols like TCP/IP, Modbus, Modbus TCP/IP, IEC-101, IEC-104, etc. You can find a better solution for your system with this solution.
For any kind of support you can login to http://www.pmas.in or mail at support@pmas.in
jain
Posted by Jeremy Pollard on 19 January, 2008 - 8:02 pm
Maxstream (now digi) has 2 900 mhz modems for less than 700 bucks for the pair .. point to point .. no config.. just plug them in..
They work good!!
Cheers from: Jeremy Pollard, CET The Caring Canuckian! www[.]tsuonline.com
Control Design www[.]controldesign.com
Manufacturing Automation www[.]automationmag.com
3 Red Pine Court, RR# 2 Shanty Bay, Ontario L0L 2L0 705.739.7155 Cell # 705.725.3579
Posted by LeBlanc on 22 January, 2008 - 10:39 pm
I have currently (10) 1100E working at a Water Plant on a wireless network. Before I installed them I tested them in my shop with Maxstream, Datalinc and Synetcom wireless radios. I had no problems with any of them. You will have to be more specific on what issues you are facing. One thing to check is the firmware. If your 1100Es have firmware 3 or below you need to upgrade them. Firmware 3 and below have Ethernet communication problems. Also make sure you are not messaging your information too frequently, AB has an extremely cumbersome overhead in their IP packages.
Advertisement
