Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Speed is subsittute fo accurancy."
www.control.com/rss
Implementation of Modbus TCP/IP between two PLCsHello!
Can somebody help us? We have two Siemens S7 PLCs and we want to implement Modbus TCP/IP between thoose two, but we also need to implement Profibus from one of the PLCs to a laptop with LabVIEW. And we must program the PLC between Modbus TCP/IP and Profibus in SCL-language. Any suggestions?
Best regards,
Tony
Best regards,
Tony
You want to use Modbus/TCP between two Siemens PLCs, and Profibus from a Siemens PLC to Labview on a PC? And you have to program this in SCL? That sounds like doing things the hardest way possible. Is this supposed to be a special challenge?
I haven't tried that (nor can I recommend it). It might be a lot easier to use Profibus between the PLCs, and Modbus/TCP to the PC.
A quick search on Google turns up Modbus/TCP for the S7-300, and Modbus/TCP for Labview. Have a look on Google for "S7 Modbus TCP" for more links. You will find that about half the top rated links go back to pages on this forum. I suggest that you read those as well.
http://www.industry.siemens.com/IT4Industry/en/solution_services/s imatic_addons/proto_mod.htm
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201711
Tony, This post might help you with the Modbus TCP in S7: http://forums.mrplc.com/index.php?showtopic=12162
Depending on the version of LabVIEW (8.0 and up), Labview has a built in Modbus I/O Server (master or slave) with shared variables and you do *not* need the DSC toolkit.
To get LabVIEW talking on Profibus see this link: http://sine.ni.com/nilex/DisplayLinkAction.do?id=12184EXT
David
David
Hi there,
I would suspect that the easiest way to solve it, is to use a gateway Profibus slave to Modbus TCP slave. For more information, go to:
http://www.anybus.com/support/support.asp?PID=244&ProdType=Any bus%20X-gateway
or email me at: support@hms.se
/Pat
/Pat
Related articles from Control Engineering magazine- OPC: Painless migration, classic OPC DA to OPC UA, partership
- Easier: panel designs, short-circuit current rating compliance
- MechatronicsZone road show kicks off
- Partnership: Advanced, interoperable motion control, machine tools
- Protect intellectual property: Encrypt firmware, control code
- Portable computing: Operators can be mobile with rugged HMI
- Whitepaper: Small form factor HMIs evolve
- Remote control: Get behind firewalls—securely
- Report asks: Will DIN-rail PCs with I/O revolutionize industrial PCs?
