member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Love your enemies: they'll go crazy trying to figure out what you're up
to.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the instrumentation department...
solenoid valve coil resistance
Posted by bans on 19 January, 2008 - 8:06 pm
i checked resistance of an solenoid valve coil with multimeter and it shows OPEN connection so i presumed that valve is damaged. but when i connect the supply (110 VAC)to it, i found the the coil still energizes.
if any one is able to figure out the reason
thanks in advance
Posted by roy Matson on 20 January, 2008 - 5:47 pm
Bans,
It sounds as though there is some solid state device connected in the circuit. e.g. is it rectified or has some sort of economy device typical of a large DC coil where the holding current is only a fraction of the initial closing current. The voltage of your multimeter may be reverse biased or too low to overcome the forward bias. Another possibility is a faulty connection but I think the former is more likely If you post the make & part No I'm sure someone can figure it out.
Roy
Posted by anonymous on 21 January, 2008 - 12:38 pm
Is the coil rated for AC?
What constitutes an 'open circuit'? A measurement with an analog VOM meter on 10 ohm scale and the needle pegs out?
I know some current solenoid valves have 'electronics' embedded with the coils.
Page 3 of ASCO's white paper at
http://www.ascovalve.com/common/pdffiles/product/engineering.pdfshows a cap in parallel with a resistor, both of which are in series with the coil. However, it is described as a 'simple circuit', not necessarily that which is used in practice.
Internet Explorer 6.0 Fix
Advertisement
