We are facing an intermittent problem with our temperature processing module of Mark-II based GE gas turbine. “Ground Lamp” of SGDD (Ground Detector) card is flickering “on” and “off” at different intervals. SGDD card has three channels, one for temperature control system “Tx” and remaining two for temperature protection system “OTA” and OTB”. Lamp affiliated with “Tx” is flickering while others are ok.
We have rejected the exhaust thermocouples of temperature control system one by one, whenever indication persists for few minutes, but alarm did not vanish. This apparently shows that problem is not with thermocouples and it might that the SGDD card is faulty. Please guide us in this regard and inform us whether we can change the SGDD card online (Turbine is in running condition). Your early reply would be highly appreciated.
