Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
I've enjoyed just about as much of this as I can stand.
www.control.com/rss/
We will build a SCADA system using Modbus/TCP Protocol. SCADA Host (SCADA software) will be client and read data from PLC/RTUs, which are thought to be servers. However, RTU/PLCs need to communicate with each other also. So, for an RTU/PLC, is it possible to open double socket/channel (via ethernet port) one will treat as Client and the other will treat as Server? Or will we need 2 ethernet ports for this purpose?
Best Regards,
Okan Benli
Best Regards,
Okan Benli
Sometimes nomenclature can get mixed up.
Ethernet is the media and does not care about the protocol.
I have a PC with an Ethernet port and some software that acts as a MODBUS master and connects to a device (XYZ) that acts as a MODBUS slave.
If the device (XYZ) is capable, it can act as a MODBUS master and connect to a MODBUS slave.
A device can be a master, slave or master/slave.
It would be normal for the device to allow all communications through one Ethernet connection.
The PC I am typing this on will communicate with MODBUS masters, MODBUS slaves, AB EtherNet/IP, Automation Direct, etc all at the same time.
It comes down to the software of the device. Ethernet will not be the limitation other than physical connections. (needing a hub or switch, etc)
Hope that helps.
Cheers,
Mark
www.hmisys.com
Hope that helps.
Cheers,
Mark
www.hmisys.com
Related articles from Control
Engineering magazine- Free webinar on Zigbee for embedded systems
- WirelessHART compliance verification receiver available
- PTO reports high growth, cross-industry collaboration
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- New products: Supporting wireless communications at every level
- NIWeek: National Instruments targets WiFi, Ethernet, adds LabVIEW 8.6
Subject to its Terms of Use.
