Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Ah say, son, you're about as sharp as a bowlin' ball.
www.control.com/rss/
I need to connect a barcode reader to a M340 PLC that has 1 ethernet port (just messaging service) and 1 CANopen port and the only way that i´ve come to is with a SICK scanner through CANopen but its a really expensive solution. Does anybody knows a cheaper option?
You could use an Ethernet (Modbus TCP/IP) to Modbus ASCII gateway such as Schneider Electric ETG100. Assuming you are not actually using the Canopen for anything else, you should have bought a M340 with Ethernet and serial port. It is not possible to add a serial port to any M340 system. It has to be on the CPU to start with.
The ETG100 is £285.00 UK list price.
Hi there,
I agree, the use of a gateway is probably the easiest/cheapest way to go. HMS has two gateways that will do the job, one for CANopen and one for EtherNet.
For more info, go to:
(EtherNet)
http://www.anybus.com/support/support.asp?PID =110&ProductType=Anybus%20Communicator
(CANopen)
http://www .anybus.com/support/support.asp?PID=107&ProductType=Anybus%20Communic ator
or email me at: support @ hms. se
/Pat
(EtherNet)
(CANopen)
/Pat
Related articles from Control
Engineering magazine- Free webinar on Zigbee for embedded systems
- WirelessHART compliance verification receiver available
- PTO reports high growth, cross-industry collaboration
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- New products: Supporting wireless communications at every level
- NIWeek: National Instruments targets WiFi, Ethernet, adds LabVIEW 8.6
Subject to its Terms of Use.
