Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
When I woke up this morning, my girlfriend asked if I had slept well.
I said, "No, I made a few mistakes."
-- Steven Wright
-- Steven Wright
www.control.com/rss
from the :>{ department...
Best way to switch D.C Coils...I am starting an upgrade of a Desma Rotary Injection Press which uses 200vdc coils for its hydraulic valves. What is the best way to switch this load?
I have upgraded other Injection presses, but they use 24vdc coils and I used Opto22 solid-state switches. It hasn't been easy to find a solid-state device for this voltage. What about relays and suppression? Anyone with any experience in this situation?...
Eric,
200 DC seems an odd voltage, are the coils quite large?
The Opto22 relay outputs use reed relays and won't handle much power without welding shut.
Perhaps you could use a solid state AC output module with a separate rectifier for each coil, that must be cheaper than replacing all the solenoids. You would need a transformer wound to give the correct DC voltage.
There are other ways of controlling DC coils that I wouldn't try to convey without a sketch.
If you are interested send me a simple wiring drawing and I will respond. roy_matson@yahoo.ca
Roy
Roy
HexFETs come to mind as they could be easily
driven by PLC transistor outputs and are
fairly hardy in inductive switching. It's a rather odd voltage for automation stuff. I would use appropriate suppression in any case as 200 VDC coils could have fairly high inductance. Products packaged for automation might be hard to find.
cww
cww
There are some industrial products available that might fill this need such as these DC switching solid state relays:
http://www.power-io.com/products/hdd.htm
http://www.crydom.com/products/productFamily.aspx?id=39
http://www.teledynerelays.com/industrial/s60dc40.asp
You will need a diode for suppression across the solenoid.
Whatever you use to drive it, relay or Transistor, make sure that you use a flyback diode, or Zener Diode across the coil (See internet or textbook if you are unclear as to configuration). This will keep your coil from generating infinite voltages (or better said, approaching infinity until it cooks some component). You probably want to use a flyback diode unless your off switching time is very critical.
Make sure if you have an unregulated DC power supply to switch the coil that your drive circuit can handle the *peak* voltage of the ripple of your Transformer/Rectifier/Capacitor type power supply. 120VRMS for instance has a peak of 170V (multiply by square root of 2).
~KEJR
~KEJR
Thanks for all the input. Because of price I will probably go the way of relays and snubbing. The original system uses limit switches and general purpose contactors to switch the 200vdc coils(and has done so for 30+ years!) I was given some excellent sources for future use and and very appreciative of them.
Thanks everyone.
Thanks everyone.
Related articles from Control Engineering magazine- OPC: Painless migration, classic OPC DA to OPC UA, partership
- Easier: panel designs, short-circuit current rating compliance
- MechatronicsZone road show kicks off
- Partnership: Advanced, interoperable motion control, machine tools
- Protect intellectual property: Encrypt firmware, control code
- Portable computing: Operators can be mobile with rugged HMI
- Whitepaper: Small form factor HMIs evolve
- Remote control: Get behind firewalls—securely
- Report asks: Will DIN-rail PCs with I/O revolutionize industrial PCs?
