Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Unix: Some say the learning curve is steep, but you only have to climb it once.
-- Karl Lehenbauer
-- Karl Lehenbauer
www.control.com/rss
from the Rung modification department...
Sub rung modificationWe would like to add a new signal in the cooldown sequence in the MKV panel. But we have come accross an hurdle as we opened the above rung using the seqedit.exe file, (normally we used to do some small modifications in the rung display without any problem) in the page we opened we have a list of signals all related the cooldown the segment were we have to add the new signal for the vapor evaporator. Now we would like to know how to edit the sub rungs under the above rung, would be grateful if anyone could give us the procedure to edit the sub rungs using the seqedit.exe file.
Thanks in advance,
Brian
Thanks in advance,
Brian
One cannot modify logic in a sequencing BBL; it's coded in the PROM.
One can re-write the sub-rung as required immediately after the sequencing BBL (just "below" it). This will result in a warning message that the coil has multiple writes (one inside the sequencing BBL and one outside); "the last write wins" in each scan of the CSP.
Related articles from Control Engineering magazine- Rockets or cars: Who, what was your engineering spark?
- Think big: Widescreen operator panel for industrial use, 25% more information
- Analysis: Control Engineering Top 20 articles of 2007
- OMAC: Open technologies, sharing best practices help integrate discrete, process manufacturing
- Security: ISASecure targets conformance
- Secure HMI/SCADA software supports handheld, desktop thin clients
- Maximize workspace: Wall-mounted, operator interface enclosure for constricted areas
