member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
Fame is a vapor; popularity an accident; the only earthly certainty is
oblivion.
-- Mark Twain
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
CL programm in TDC3000
Applications topic
Posted by haris chaudhary on 27 January, 2008 - 10:01 pm
I am working on TDC3000 dcs I need help regarding cl programm. I am starting fans through CL. I need that when Fans are start from programm, its control came back on manual. Now fan started through Digital composite point, it is on manual. i want this point in maual after fans start. Below is CL program.
IF TC018.PVHIFL=ON
& THEN (SET 41HS085.MODATTR=PROGRAM;
& SET 41HS085.OPCMD=OFF;
& SET 41HS085.NMODATTR=OPERATOR;
& SET 41HS085.MODE=MAN;
when ever hi flag is on fans is start, at this time its mode is PROG-MAN,after starting of fans I need this control on maual, but is is not coming on maual, its remain on PROG-MAN. Please help me regarding this matter.
MUHAMMAD HARIS
Posted by M. Friedrich on 28 January, 2008 - 11:54 pm
Change this parameter to MODATTR and it should work:
I hope that is not the complete code, otherwise the program will change the composite point every time it's execute and the hi flag is active.
Markus
Posted by John on 29 January, 2008 - 12:59 am
Looks like this parameter needs to be changed in line 4:
To:
& SET 41HS085.MODATTR=OPERATOR;
NMODATTR identifies the normal mode, but doesn't switch modes.
Posted by Ashraf Mabrouk on 4 May, 2008 - 8:29 pm
the best thing will be using a logic block to switch the mode to MAN when hi flag comes on. CL will make it P-MAN because you are changing the MODEATTR to PROGRAM.
Advertisement
