Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Hailing frequencies open, Captain.
www.control.com/rss
from the Controls department...
Control of PLC via GSM module by SMSHi there,
I want to command a PLC controlled plant system remotely with the help of an SMS using GSM modem.
The user should be able to control the start/stop of the plant pumps as well as verify the status of them via a set of pre-programmed commands through SMS.
Can anyone please help me out in this regard??
>an SMS using GSM modem. <
Are you designing from scratch or you have to deal with an existing installation? That is, which PLC do you have to command?
>SMS. <
If you work with SIEMENS S7-200, there are 2 ways for receiving SMS with a modem GSM:
1. Push-style: configure the modem to tell the PLC when a SMS is just received.
2. Pull-style: configure the modem to store the SMS and then the PLC asks the modemm for incoming SMS.
The second option is clearly more robust, because you will not have unexpecting comunications from the modem in the freeport comunication.
The configuration for this is AT+CNMI=0,0,0,0.
Then your PLC must ask periodically for new SMS. The AT command for this is AT+CMGR=1 (inbox 1). You will get the SMS in the V memory and then you can analyze it.
You will need however expert programming.
If you want to save time and gain robustness and flexibility, there is a library for STEP7-MicroWIN that solves the problem, Nubitek_SMS_Manager.
Have a look at:
http://www.nubitek.com/section02/pr01-sms_mgr.htm
You can download and test it for free.
Here you can also have a look at visual examples of use, like 'Communication in distributed installations':
http://www.nubitek.com/section03/examples.htm
Hope this helps!
J.C.
>SMS. <
Have a look at:
Hope this helps!
J.C.
Related articles from Control Engineering magazine- OPC: Painless migration, classic OPC DA to OPC UA, partership
- Easier: panel designs, short-circuit current rating compliance
- MechatronicsZone road show kicks off
- Partnership: Advanced, interoperable motion control, machine tools
- Protect intellectual property: Encrypt firmware, control code
- Portable computing: Operators can be mobile with rugged HMI
- Whitepaper: Small form factor HMIs evolve
- Remote control: Get behind firewalls—securely
- Report asks: Will DIN-rail PCs with I/O revolutionize industrial PCs?
