Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
For some reason, this fortune reminds everyone of Marvin Zelkowitz.
www.control.com/rss
a question for RSView32 VBAI would like to change a memory variable initial value, I used the following statement.
Sub ChangeWellValue()
Set Well1 = gTagDb.GetTag("TP_pump\Well1")
Well1.InitialValue = Well1.Value
End Sub
When the RSView32 is in Runtime, the initial values of variables memory is 0. I set a 7, and the initial value was changed to 7, but the variables in the database, the initial value is not changed at the next re-running and the initial value of variable memory is still 0. I would like to ask how can I storge the changed variables initialvalue at the next re-running time?
End Sub
can you change the .initalvalue field from vba?
Initial values should be set in the tag database.
The tag value can be changed during runtime and retained in program memory until the next time a "boot" occurs.
A "boot" will reference the value contained in the tag database until your subroutine is called.
My personal experience is as follows:
Set your database values.
Do not try to change baseline values with code.
Code exists to handle human interaction not program sequence.
How can I pass a tag in parameter with a button?
Related articles from Control Engineering magazine- HMI/SCADA: Microsoft Fluent technology helps enhance Proficy iFIX 5.0
- HMIs: NASCAR pit crews, Vista users get Simatic options
- HMI: Monitors, graphic panel improve images, offer ruggedness
- Listen in exclusive: Wonderware Innovation Partners to create vertical software faster
- Listen in exclusives: Wonderware launches innovator program; Kepware helps Wonderware
- Operator Interface Outlook Clear, Bright
- Solid HMI Connections, Sealed Edges Prove Tough Enough
- Less than 6 year doubling: Touchscreen shipments, new products
