I/O Channel Density in ESD PLC Cards
Boomba
Can somebody explain what is the reason for the channel densities being in powers of 2? Also, from the process point of view, is there any advantage/disadvantage in using a card with higher densities?
It is a question of how many points ( read equipment in the larger picture) is affected if a card fails. Traditionally it was 8 or 16 for inputs and 8 for outputs. Nowadays 16 is defacto for inoputs but outputs still remain 8 since most cards cant handle higher currents ( 8 means 4A at 0.5 A per channel)
