Jump to a Date
Twitter Feed
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
If you have a procedure with 10 parameters, you probably missed some.
www.control.com/rss/
I get an illegal exit code! Please shutdown the computer Message when i restart the HIS on the centum 3000 system.
Has anyone seen this error code befor..
regards Jim
regards Jim
Hello Jim.
I received this error numerous times with our 3000 system years back. I never did figure out what causes it. At first I suspected the Centum Software was corrupted, but on a reinstall the same error would occur.
A complete format and reinstallation of the OS in question usually fixed the error. In one instance, after I reinstalled Win NT several times, and still received the same error, I eventually found one of the DIMMS to be faulty. I suspect this is just a default error code that is issued when Centum encounters an unrecoverable error. Check the software first, particularly if you are using Windows. If the problem persists, it more than likely is a hardware issue which is causing software problems (faulty CPU fan, overheating, faulty RAM, etc.)
Cheers.
Warren
Cheers.
Warren
Warren,
Thanks for your help. I also am not sure what the problem was. I re-installed the Centum software and reloaded the VL-Net card drivers but did not remedy the problem.
I ended up re-imaging the the whole HIS back to it's original state since I had previously taken a Norton Ghost Image of all the HISs in the Project. As you say it may be a memory problem of sorts. The Yokogawa engineer that contacted be suspected the VL-net card driver but after I reinstalled it the problem was the same.
Jim Mete
Jim Mete
Dear Jim,
When you get Illegal Exit Code, try this.
Go to key code folder in CS3000, then do the following:
Ctrl+x, then save the files in some other folder outside Centum. Restart PC & then put back those files in Key Code folder. Now restart again, and check.
Please let me know your feedback.
With Best Regards,
Pallab Basu
With Best Regards,
Pallab Basu
Dear Pallab,
Thanks for this insight into the workings of the CS 3000 software.
For now I have solved the problem by re-imaging back the original software but the next time I have this same problem I will try as you suggest.
Jim Mete
Jim Mete
Follow the steps below:
1) Uninstall cs3000 completely
Stop all BK... related process
check HIS property
uninstall cs3000
Delete all the relevant folders
2) Restart the system
3) Install the cs3000 software
4) Restart the system
5) Now open the test function and HIS functionality
check HIS property
uninstall cs3000
Dear Anonymous,
Thanks for your help. I will try this on one of my standby systems.
Regards...
Jim
Regards...
Jim
Hi Jim,
Illegal exit code appears because of BKWAIT.exe process running at ur taskmanager.
When u start ur CS3000 it will first search for some basic drivers like vnet driver etc.
this error might come when u have disconnected ur vnet and try to reboot the his and mean while vnet driver fails.
Formatting the system and reinstallin CS3K is the ultimate solution but before this u can try stopping bkwait.exe and perform download of HIS. This works.
Jigar
E-mail: anadkat.jigar [at] gmail [dot] com
Jigar
