Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Center meeting at 4pm in 2C-543.
www.control.com/rss
Honeywell TDC 3000 helpHow do I collect data from a Honeywell TDC 3000 to my Windows PC?
I have just recently become the site engineer for a company that uses a Honeywell TDC 3000. I have no DCS experience (previously a process engineer). I am looking for help mostly with data collection.
My previous company used Aspen InfoPlus, which was great, but my current company is small, and probably cannot afford a product like that. I would be happy with 12 analog outputs in a 1 minute history, and total weights of the raw materials for each batch (3-5 batches per day).
I need any help I can get! If you can recommend a good textbook on the honeywell, that would be great, also. Thanks!
If you're looking for a at-the-source data historian, have you considered OPC?
http://www.matrikonopc.com/products/opc-archiving/opc-desktop-hist orian.aspx
If you have an App Node on your TDC3000, you probably already have the Honeywell OPC Server, the TPN Server. You can historize any Honeywell Point.Parameter from the OPC Server into the Desktop historian.
If you don't have an App Node, there are other OPC server options to access the TDC3000.
http://www.matrikonopc.com/drivers/dcs.aspx
A simple option is to write a CL program to generate a FFL report every minute. This report can then be directed to a text file (with GUS and virtual printer configured). An alternative is to send the FFL to the COM port and retrieve via a PC or capture software.
A similar solution is on the following website:
http://www.procdev.com/software_reportCapture.asp
OPC server is one option to retrieve data.
You can also use PCIM (personal Computer Interface Module) or CG (Control Gateway) on your LCN to communicate with your Windows but I suppose that these are outdated.....!
I m not sure but you can enquire about LCNp4 card and MAU to take data on EST also.
Good luck
Good luck
Related articles from Control Engineering magazine- Integrating PLM, ERP, MES behind the scenes
- Enterprise data historian supports management of power distribution
- Digital factory interface: XML control logic standard accepted by AutomationML
- Colfax Corp. acquires Fairmount Automation
- Oil & gas industry controller benefits from embedded database
- Wonderware names InSource “Wonderware Southeast” partner
- Researcher wins grant for holographic instrument panel controls
- Rittal launches Ri4Power power management system
