Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
You do not have mail.
www.control.com/rss
from the Cylinder Linear Actuator department...
Small 100% Duty Cycle Linear ActuatorLooking for small linear actuator with stroke of 2-4 inches. Force requirement is only about 5-10 lbs. Firgelli's L12 model would be great however my application requires nearly a 100% duty cycle and they only offer 20%. Is this just due to heat buildup?? Size requirements are tight as both extended lenth and width and height must be minimized. Width and height MUST be less than 2" x 2". Control within 1/16" will also be necessary.
Any suggestions?
Any suggestions?
Most actuators have a rated duty cycle at the rated load. If it is a ballscrew actuator, you should be able to use the actuator at 100% duty cycle, but at much less than rated load. If it is an acme screw actuator, then you have to be more careful. An acme screw actuator with a plastic nut will overheat even with no load. It is best to contact the actuator manufacturer to let them guide to the correct actuator.
If you can use a ballscrew, the THK KR15 is really small and the precision units are nice.
Check out the Linak LA12. These are rated 100% with 12 or 24 VDC drive. I just purchased 6 of these.
Roy
Roy
Related articles from Control Engineering magazine- MechatronicsZone road show kicks off
- Partnership: Advanced, interoperable motion control, machine tools
- Vibration: Training, transmitter, accelerometer, displacement sensor
- Electroindustry managers: April survey shows decline, less confidence
- For faster startups: FKI Logistex expands system integration services
- ABB update: User conference, exhibition, flow, SCADA, wireless
- Fun engineering: FIRST Robotics Championship
- Sensors: Measure six degrees of freedom
