Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
If you teach your children to like computers and to know how to gamble
then they'll always be interested in something and won't come to no real harm.
www.control.com/rss
Low speed, low voltage generatorHi,
I need to implement a generator for my project using a small PM AC motor. The shaft speed would be 200 RPM to get output voltage of 12-15 VAC at 10-15 W. I have 2 questions:
1. How can I relate the motor specs (input voltage and output RPM) to my requirement?
2. [Can you recommend] some vendors for this small kind of AC motor.
Alex,
I don't think permanent magnet AC motors are that common, I can only think of 1 used in a washing machine by Fisher and Paykel. These 3 phase multi-pole motors are very popular for micro hydro and wind powered alternators. They would certainly put out what you require at 200 revs. Most of the DIY guys open them up and reconnect the colis for lower voltage. As a rule of thumb I would think a motor would generate a similar voltage to that it's designed to run on.
BTW it's an alternator, generators are DC.
Roy
Roy
Roy,
Yes, the motors will generate close to what they run on if they are running at design speed. If they run below design speed they will generate proportionally lower voltage.
Eric
Eric
With this low speed, you may need a bigger motor than you like. See http://www.anaheimautomation.com/BLZ36_Series__Brushless_DC_Motors.aspx, in particular BLZ362S-320V-3500. It seems to be the one selling for $147.40 at http://www.anaheimautomation.com/brushlessdcmotors.aspx This one is 6.6 lb, 5.03 inches long, and 3.62 inches square. This motor is 3 phase AC if used as a generator.
Eric Ratliff
www.icpdas-usa.com
Eric Ratliff
www.icpdas-usa.com
Alex,
Here is a link to the motor I mentioned:
http://www.thebackshed.com/Windmill/AssemblyA.asp
Roy
Roy
Roy,
Yes, alternator not generator. I looked at the motor you were talking about. Wow! 42 poles is a lot and I suppose this would run well at low revs.
I also want to mention that the motor I specified would put out the volts you need at zero load. As you draw up to the full 1A load, there will be some loss of voltage due to resistance of the coils.
Eric
Eric
Eric,
Yes, it is an interesting motor as is the washing machine, no gearbox, 1 moving part. Reverses back and forth to get the usual wash action with lots of different cycles and very quiet. Made in GodZone as we Kiwis call NZ but now invading Nth America.
Roy
Roy
Related articles from Control Engineering magazine- Integrating PLM, ERP, MES behind the scenes
- Enterprise data historian supports management of power distribution
- Digital factory interface: XML control logic standard accepted by AutomationML
- Colfax Corp. acquires Fairmount Automation
- Oil & gas industry controller benefits from embedded database
- Wonderware names InSource “Wonderware Southeast” partner
- Researcher wins grant for holographic instrument panel controls
- Rittal launches Ri4Power power management system
