- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
an unpitied sacrifice in a contemptible struggle.
- Edmund Burke
www.control.com/rss
In generally, starting method will be decided by load type, utility power and etc.
Is it correct that "Soft starter must be selected in case of 75kW over"?
The most important factor to consider when choosing a motor starting method is capacity of the supply system! Or, perhaps, the size of an intervening transformer that reduces supply voltage to utilization voltage!
Horsepower limits are imposed because of constraints normally by the power supplier or utility! As an example, I personally know of a 19,000 Hp machine designed for DOL (Direct-On-Line) starting at 11-kV!
Of course there are some restrictions, that is, excessive voltage-drop might be experienced by other parts of the system! Other times the load is not able to withstand the mechanical stress produced by the rapid acceleration associated with DOL starting.
Who told you that 75-kW machines needed soft-starting? The utility, or a motor starter vendor?
Regards, Phil Corso (cepisicon@aol.com)
- PTO reports high growth, cross-industry collaboration
- New, efficient industrial gas turbines coming
- Wireless helps Hexion with smoke detection, control room reporting
- Wireless networks for water and wastewater plant: easy, timely info access
- What process control applications are OK for wireless?
- Chemical company processes critical data via wireless Ethernet
- Enclosures: Improve NEMA designs, enclose wireless equipment, keep cabinets cool
- Affiliate integration: Advanced Automation, IAEF and EIAL become Avanceon
- Product experience: Who leads in 2008 with automation system integrators?
- Controller platform: Small-scale system bridges device gap
