Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Good night, Austin, Texas, wherever you are!
www.control.com/rss
from the Maintenance department...
50 hp motor connectionI have a question.
We have a 50 hp motor running having rated current of 75 amps. This motor winding is connected in star and the starter used is a DOL starter(Direct 0nline). The motor is running at close to rated HP.
My question is if we now connect the motor winding in delta what will happen to
1) starting current
2) running current
3) starting and running torque
4) Will the mechnical load it is driving get affected.
5) Normally which is the configuration in which a motor needs to be connected during running.
Hope i am clear in my in what clarification i seek
1) starting current
2) running current
>I have a question.
>to rated HP.
>to
>1) starting current <
Will go up considerably
>2) running current <
As above
>3) starting and running torque <
Starting torque will go up but running torque should stay the same for same load
>driving get affected. <
Yes the additional starting torque will put extra stress
>during running. <
This depends on the voltage you shouldn't connect in delta unless it's designed for it.
Please give the system voltage Phase-phase Nameplate voltage.
Roy
>to rated HP.
>to
As above
>during running. <
Roy
Dear Thompson,
Starting current in case of delta will increase in this case. You may use an AC current measuring clamp meter to measure it.
Running current in delta configuration, you may easily find on the name plate of the motor. Similarly you may measure it as per actual in running condition.
Torque is related to current.
Mechanical stresses increase with increase in starting current.
Star or delta in running condition may be decided by you depending upon RPM you require during running operation as mentioned on the name plate.
If there are more mechanical stresses leading to frequent break down, then you must use soft starter for your application.
Related articles from Control Engineering magazine- OPC: Painless migration, classic OPC DA to OPC UA, partership
- Easier: panel designs, short-circuit current rating compliance
- MechatronicsZone road show kicks off
- ODVA, DeviceNet: New CIP specs; ControlNet added; 2009 meeting
- Partnership: Advanced, interoperable motion control, machine tools
- Protect intellectual property: Encrypt firmware, control code
- Embedded, wireless devices, dynamic IP routing
- Portable computing: Operators can be mobile with rugged HMI
