Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Drive defensively. Buy a tank.
www.control.com/rss/
In a Frame 5 Turbine, the reduction in inlet temperature to compressor produces more power. I wish to know if it also improves Gas consumption per unit of power produced and why?
When the inlet temp is low, the mass flow is better. Does it mean that more air is available for combustion and hence the combustion is more efficient? Does more mass flow lead to higher combustion temperatures and hence higher kinetic energy of gases and hence the higher power?
Thanks,
Ivan
Thanks,
Ivan
This is not particular to Frame 5 gas turbines; it's true of all gas turbines. Higher mass flows, which can result from decreased compressor inlet temperature, results in higher power output than for lower mass flows at higher compressor inlet temperatures.
If we're talking about operation at compressor discharge pressure-biased exhaust temperature control ("Base Load"), no; the combustion temperature does not change with changes in compressor inlet temperature. Exhaust temperature will change--inversely--with compressor inlet temperature changes when operating at Base Load, but combustion temperature will not change. More air will allow slightly more fuel to be burnt for the same combustion temperature at Base Load, and I believe that gas consumption per unit of power production does improve slightly, or else why would chillers and foggers and evap coolers be so common (as they are used to decrease compressor inlet temperature to make more power and if that came at an efficiency deficiency they probably wouldn't be so common).
I would suggest you surf over to the Mee Fogger website for some information on efficiency and heat rate improvement with inlet cooling. Also, many of the other manufacturers of inlet cooling equipment may also have some literature that will have some data you are probably seeking (heat rate?).
Related articles from Control
Engineering magazine- Wonderware focuses on front-line innovation
- Wonderware announces new system integrator certification
- Mobility dominates WonderWorld partner and technology expo
- CAD / project management integration supports distributed engineering
- OPC Foundation to release analyzer devices integration draft specification
- Wonderware applauds users of winning applications
- Embedded automation: Compact computer supports multiple operating systems
- Display panel has built in functions, diagnostics
- Pepperl+Fuchs acquires Christensen Display Products
- Hot news in temperature: Industrial thermostat, infrared linescanner
Subject to its Terms of Use.
