I have a PLC that I think is receiving a rogue message. There is a bit that is set for no apparent reason and there is nothing in the local ladder logic to set that bit, so I suspect it is being set from another PLC on the network. I've scoured all the other sites but cannot find anything that might be causing the problem. I'm wondering if there is a way to capture the most recent packet received on channel 1 and store that. This way when the bit in question is set I can hopefully see what node the last packet was received from.
I'm using the DF1 Radio modem protocol. If anyone has any other ideas of how I can track this down I'd be grateful for the suggestions.
Thanks,
Jeff
Thanks,
Jeff
