- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
-- Hunter S. Thompson
www.control.com/rss
We have SIMPLEX MARK V system installed on GE frame 5 turbine. We found an intermittent “Diagnostic alarm” while turbine was running smoothly following sequence of alarm was seen:
U SA P DROP DESCRIPTION
T2 0* C 1896 Voter mismatch, <Z> L3CRZ
T2 0* C 1864 Voter mismatch, <Y> L3CRZ
T2 1* C 1832 Voter mismatch, <X> L3CRZ
First of all “Voter mismatch <Z>” appeared for a moment and went away. Then “Voter mismatch <Y>” appeared and disappeared after a while. Similar thing happened to “Voter mismatch <Z>”. Now the situation is that alarms are gone and turbine is running (Turbine didn’t trip during whole of process). Kindly share your experience if anyone faced such problem and especially if you can comment on
1. What could be the cause of this problem?<br>
2. How can we solve this problem?<br>
3. Can we keep turbine running in this situation?
An early reply is appreciated.
- Temperature, relative humidity sensors pair with SureCross Wireless Network
- Intrinsically safe accelerometer expands line of hazardous area sensors
- Power: Digital converter growth; fuses, harvesting, supplies, transformers, UPS
- Terminal blocks: 125 A, 1,000 V, 15 mm pitch; 100 kA short circuit current rating
- Industrial Ethernet: High density I/O, no-tool RJ45 Ethernet connector, extenders
- RFID: Tag for boxes or polymeric containers, future trends, training
- Enclose, protect: 2 plastic enclosures; device measures heat, airflow
- Control Engineering System Integrators Hall of Fame
- Process safety system: Flexible platform designed to increase plant profitability
