member
passwd
remember me on this computer.
- join now -
Select a topic of interest:
...and press:
Two percent of zero is almost nothing.
www.control.com/rss
Select a Page Style
- BluFu
- Classic
(cookies required)
Profibus Communications
PLCs topic
Posted by Nijamudeen on 21 April, 2008 - 1:03 am
In our machine, the Siemens S7-400 CPU, OP 37 and field ET 200 modules are connected with Profibus cable. I want to connect my laptop to Profibus port in order to get the PLC ladder programs via Step 7 software.
Thanks.
Posted by kevin grey on 23 April, 2008 - 12:10 am
Use the MPI/Profibus programming adpator, this is available in USB and RS232 (if you can still get the RS232 version).
Posted by nt on 23 April, 2008 - 12:26 am
If you want to use a USB port then you need this device from Siemens:
6ES79720CB200XA0 - SIMATIC S7, PC ADAPTER USB F. CONNECTION OF S7-200/300/400 C7, WITH USB-CABLE (5M) CAN BE USED UNDER WIN 2000/XP
Posted by gabi on 23 April, 2008 - 12:30 am
The Profibus is a communication on RS 485 port, on laptop you have to search for an MPI/PROFIBUS PCMCIA card adapter. Ex: http://www.mysst.com/cards/profibus/pfbpcm.asp
Posted by zare.v on 23 April, 2008 - 1:39 am
There is a MPI port on the CPU that you can communicate with CPU and uploading the ladder software to PC.
BR,
Vahid
Posted by dchartier on 23 April, 2008 - 11:02 pm
Here are a few USB-to_Profibus adapters that you can look at:
from Woodhead/SST:
http://www.woodhead.com/products/automation/networkinterface/nic/p rofibus/
from ABB:
http://library.abb.com/GLOBAL/SCOT/SCOT211.nsf/VerityDisplay/C6D6D A7E98A20876C12572370044B592/$File/63_631-EN-A-12_2006.pdf
and finally from Siemens, of course:
http://support.automation.siemens.com/WW/view/en/16983464
Hope this helps,
Daniel Chartier
Advertisement
