I have a device which can act as a Modbus master and can be set-up to poll or write a set of addresses on a modbus slave. As far as I can tell it doesn't accept unsolicited writes from the Modbus slave. If I understand correctly, when you connect a touch panel, the panel attempts to write plc addresses when a user interacts with the panel. The only way I've been able to get it to work is to place a PLC between the panel and our "Device" and poll the PLC addresses which the panel is allowed to write. Is there a cleaner solution such as some kind of bridge that will emulate a PLC and allow the touch panel to write addresses while out "Device" polls the addresses in the bridge?
