Past & Future Posts
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Don't get mad, get even.
-- Joseph P. Kennedy
Don't get even, get jewelry.
-- Anonymous
-- Anonymous
www.control.com/rss
from the PLC MAINTENANCE department...
S7 PLC200Hi to all,
We have existing S7300/400 Ver 5.1 software package installed in my PC. It has also Step7- MicroWin 32 (V3.3.1.0.3) embedded in the package. Does MicroWin32 work on S7 200 PLC family? Before I purchase S7200 PLC since my PC supports USB port I prefer to buy USB/ppi cable. Is the cable correct?
Thank you,
rey
Thank you,
rey
Yes this software work with S7 200 PLC. If you are using S7 300/400 PLC with Simatic S7 software on your PC then you have PC to MPI converter. If you have this converter I think you do not need to purchase PPI cable because MPI cable works with S7 200, 300 and 400.
Zahid Ali Khan
roxtech2002 @ yahoo. co. uk
Zahid Ali Khan
Hello rey;
You seem to have a workable system; the programming software for the S7-200 family is Microwin, and the protocol to program them is PPI, the USB-PPI cable should work. What I would check out is the version of Microwin you have installed on that PC; Siemens is now working with version 4.0, I believe version 3.2 will not support USB connections for example.
Have a look at the S7-200 system manual:
http://support.automation.siemens.com/WW/view/en/1109582
Whatever you decide to do later on, it is the complete reference to the S7-200 family, including the Microwin instruction set and S7-200 communications.
Hope this helps,
Daniel Chartier
Hope this helps,
Daniel Chartier
S7 MicroWin is now up to version 4 with SP6 just released.
Hi Daniel,
Thank you so much for your support. Have just read the manual which your link gave to me.
rey
rey
Related articles from Control Engineering magazine- OPC: Painless migration, classic OPC DA to OPC UA, partership
- Easier: panel designs, short-circuit current rating compliance
- MechatronicsZone road show kicks off
- Partnership: Advanced, interoperable motion control, machine tools
- Protect intellectual property: Encrypt firmware, control code
- Portable computing: Operators can be mobile with rugged HMI
- Whitepaper: Small form factor HMIs evolve
- Remote control: Get behind firewalls—securely
- Report asks: Will DIN-rail PCs with I/O revolutionize industrial PCs?
