- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
-- Albert Einstein
www.control.com/rss/
The problem is that there is a different of the reading between those two transmitters.
The radar transmitter range is 3-47 ft and the flange type transmitter is 1.3-20.3 PSI. 1 PSI 2.3 ft H2O.
Can you please tell me what is the accurate range for the Honeywell transmitter so the both of the reading will be the same?
Tank is used for asphalt.
Thank you all.
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
- Process modeling: Spreadsheets support multiphase flow simulation
