member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Court, n.:
A place where they dispense with justice.
-- Arthur Train
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
Modbus Requests and Java
Communications systems and equipment. topic
Posted by gishac on 26 May, 2008 - 12:36 pm
Hi, I'm trying to read data from a PM500 power meter, I'm using java to get connected, the connection is fine. the problem is I don't know the correct format to send the request to the device, the code is the following:
InetAddress ipaddress = InetAddress.getByAddress("192.168.8.42", new byte[]{(byte)192, (byte)168, (byte)8, (byte)42});
Socket xocket = new Socket(ipaddress, 771);
OutputStream output = xocket.getOutputStream();
BufferedInputStream input = new BufferedInputStream(xocket.getInputStream());
byte buffer[] = new byte[261];
DataOutputStream dos = new DataOutputStream(output);
//Here is the problem, the request I want to do is
// 01 03 03 00 00 62 C4 67, and I don't know how to build the request buffer
dos.writeByte(1); // device id
dos.writeShort(3);// function
dos.writeByte(0x0300);//register to start
dos.writeByte(0x0062); // register to end
dos.writeByte(0xC467); // crc
output.flush();
int totalRead = input.read(buffer, 0, 261);
The response I always get is -1208011111411632105115321111171163211110232114971101031010
Any idea of how to build the request buffer correctly or some code sample? I tried using jamod but I get lot of errors when I send the request, so I decided used my own code.
thanks in advance
gishac
Posted by rbk on 27 May, 2008 - 8:14 pm
Try to rebuild the code in a new the 552 series.
Posted by gishac on 28 May, 2008 - 9:19 pm
I must use PM500 series. Any idea of how to send the request???
Posted by Dave on 2 July, 2008 - 12:42 am
Hi gishac,
I'm trying to do the same thing... I found this tutorial that helps you to make a java applet that can connect to your device...
http://ltxfaq.custhelp.com/cgi-bin/ltxfaq.cfg/php/enduser/std_adp. php?p_faqid=943&p_created=1075227796&p_sid=NoP2jG7j&p_accessi bility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZw X2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSZwX3Byb2RzPTAmcF9jYXRzPSZwX3B2PSZwX2N2PSZwX 3NlYXJjaF90eXBlPWFuc3dlcnMuYV9pZCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PTk0Mw**&a mp;p_li=&p_topview=1
But the only problem I'm having is that I receive the data in ASCII and I have to change it to Decimal.
Posted by Jon Parise on 6 August, 2008 - 12:37 am
Hey,
I was able to create a Java Modbus library just by working from the online specs. If you need to understand what the packets contain you should really take a look at them.
It is fairly straight forward to create the packets once you know what they look like.
Let me know if you have questions.
Internet Explorer 6.0 Fix
Advertisement
