Hi!
My problem (problem to solve):
The company has a SCADA system for measuring and electric control. There are 13 meters (RS 485 devices) and they communicate with PC where SCADA is installed. SCADA communicates with those devices over Modbus RTU protocol. So PC is a Modbus master and the meters are Modbus slaves.
I would like to read parameters from meters with a Twido PLC (Modbus RTU). But I can not connect a TWIDO to the node because there will be 2 Modbus masters.
The question is: can be this problem solved vith a 174 CEV 300 10 bridge?
If I connect 174 CEV 300 10 bridge to the RS485 node. My PLC Twido has a ethernet port and I can send a Modbus TCP request over the ethernet and then the bridge will handle those requests and send responses from RS485 devices back to TWIDO?
So what is with the SCADA system who communicates over RS232/Rs485 converter with meters (RS485 device)?
Can there be a problem? Do I need to connect the SCADA system also over another bridge or should I just leave it?
